All the info should be out there, somewhere
More problems is when you need some real life data, like energy consumtion, power needed etc…
There are usually basic guidelines everyone tends to follow but with your skills I think u can and will be crafty enough to make your own way and things to make it work
That is really cool. I was thinking of trying a method to create a 3d model that I’d found on YouTube where you take a bunch of photos from different angles and the program stitches them together to create a 3D model.
And just a side note, mostly in case you ever deal with vendors for motor mount parts in the future, but I believe the trucks you have are generally referred to as “Matrix 1” or just “Matrix” trucks and not “Matrix 2”. Although the photo you posted does seem to create some confusion since it appears to say “Matrix II” on them. Maybe the “II” after “Matrix” are not numerals, but just cosmetic lines?
This photo shows the latest versions of MBS Matrix trucks in this order:
-Matrix I Pro
-Matrix I
-Matrix II
I’ve used 123D catch before, and it works pretty decently when viewing the model with the overlaid textures, but the actual 3d model is often pretty wonky (kinda like low-poly video games). Funny coincidence I’ve actually worked with Ehsan Noursalehi in the past (small world I guess).
I didn’t realize about the naming scheme (just used what I thought was the name on the truck), I’ll update my thread name + post
Although mine don’t seem to match any of those 3 (looks closest to the Matrix I, but mine don’t have the holes cut out)
@flywithgriff I have not made too much progress on this project.
Work has been all consuming.
I have linked to the file for the pulley I ended up making, but I have not been able to put it to use/test it yet.
It does fit on the hub, and feels quite secure though.
Hi there.
This is nearly a year later but I would be interested to see how you got on with your build as I am looking to do the same myself. In the end which esc/vesc did you decide to go with?
Thanks
would it be possible, to get the CAD-Data of the MBS-Pulley in your post (.step or.iges).
I want to change the dimensions for a 15mm belt and it´s hard to work with the .stl…
