@anorak234 Paris trucks with (slightly crooked) welded motor mount for a 63 mm motor (poorly drilled holes) with rust bolts holding an off center gear and 83 mm wheels. (This is my first ever self made drive train from years ago)
@intensivegecko $25 Pretty much new black 50 degree Caliber trucks
$80 Black Airless wheels by Diyeboards with Ceramic bearings. Ill include the second wheel pulley but I did
crack it a bit trying to swap bearings out. I’d use it for single drive.
$25 Raw Caliber 50 degree trucks (modded to fit ‘on axle’ pulleys)
$20 Enertion ‘on axle’ wheel pulley
$25 Revive deck (Had 1 major fall on it and shelved it forever)
$15 25mm wide motor pulleys (10t?) Not sure, same as the Etoxx belt drive kit
$15 25 mm belts for Etoxx belt drives
@Mobutusan (2) @Dmaxx (2 low pro) $10 A bunch of Motor pulleys in the 15 or 16 T range.EACH 2 Left not matching
$300 12s4p with Samsung 25R cells. Brand new, No switch/ display or Charger included
Enclosure with the tail is the last one right? if @Mobutusan don’t need it I would love it!
And if you even ship to Ireland so please place me near the bottom of the list.
I will make measurements and send photo of my deck and could you then tell me if it will work?
And wow them calibers are cheap I might be interested heard it works great with the turnigy motor mount let me research a bit.
Thank you so much this is the first time I ever got to a place where I could get something from a giveaway But I just remembered that I will be charging my lipos in a lipo safe bag 1 by 1 too lazy to do something smarter
I won’t be needing the enclosure thanks again still felt the joy of winning
