Torque boards kegel 16T/36T small gear will not stay no my 192kv sk3 turnigy motor I have tried blue lock tight and then red and neither of them worked after a ride of 15-20 min the gear will come lose which makes the motor not spin the wheel. The hex screws are starting to strip and I do not want to cause any more damage any solutions.
Yup! happens to everybody that hasnāt put a flatspot or keyway into their motor shaft.
So what do you suggest.
Thank you for the help I will try both
High Tolerences help also ,ā¦ i once bought a Motor gear but itās bore hole measured over 8.1mm and returned it, some companies have High standard Tolerances and thus a much more precise fit
For recommendation. Use blue Loctite and give it a few hours for the stuff to setup. Iād give it a day for it to cure. Green is not okay to long use. Blue is fine, but red will take the most to remove.
638 isnāt āgreen loctiteā itās a pulley retaining compound.
Had the same problem, made a flatspot and grub screw, never had the problem since.
