Just as long as they normally come
Aight I’m down. I am also in need of the 12mm pulley, do you think you would also be able to grind a flat spot on the motor shaft? I could probably do it but I don’t have an angle grinder, just a dremel
I can PayPal any time. Whatever is easier
Just double checking that this also has standard 6374 mounting holes? I have one of the mounts from the shogu group buy
yes it has 6374 mounting holes.
Yea I can grind you a flatspot on both sides i dont mind.
Can you purchase off of my site? You got the last one:)
Of course! And Wooo I’m lucky
Just ordered! Order #21, would appreciate the flat spots, makes my life easier. Think shipping will be about 3-5 days?
Yes once theyre in stock. should be about 3 weeks
Awesome 10char
86.30 mm !! Big Kahunas. Wayyy to large for my mounts.
Question: are there any motors in the Turnigy inventory that are not bare metal looking? Any black version?
No grinding needed, use retaining compound. I use it on the same motors.
Not that I know of. Personally I like it this way but you can paint it
If you could also grind me a flat spot that would be appreciated
Can you find one more to sell? This looks purfect for a build I’m working on. It’s fine if you can’t!
Yea potentially. I wonder if there would be interest for me to keep this item in my store full time?
I’m guessing it’ll be largely price dependent. From customer’s perspective (me), the differentiators are,
- long shaft (fits 15mm belt pulleys comfortably)
- sensored, plug n play with vesc, no sensor wire adapter
- long wires, silicone phase
- silver (not black)
- more oomph
- but hard to fit in dual setups
- 190kv a bit tight for 12s
I’d be down for one as well if you can get a hold of it.
@deucesdown It’d be the same price. Maybe $115 shipped or something. I run them on 12s all day on all my boards.
@Emerson Ill post back here if i order a bunch more. I’d do it if i got a couple preorders to lighten the load on me a bit.
I’m in dude! Anything I can do to help, still owe you big for all the help you gave me early on.
Cool! maybe i’ll do it that way then. Ill have to contact my supplier and see how many I can buy minimum
I want to congratulate you on selling a motor with the correct sensor connector for the Vesc. I don’t know why it took this long for someone to do this.
thanks! I’ll take my award now.
Nah but for real… I sell things that work for me. I’m all about easier.
Depending on price, I would stock them in the smallest quanties that it makes sense for you to buy. that way you will always have a few sitting around and if your selling out constantly you can raise your order quantity. I vote for stocking these in the store
