Update from Tech Team 10 amp psu is not enough for proper testing. We don’t think a Focbox would be ideal for a bike hub motor. Those are a whole lot larger than a skateboard motor thus need a lot more current. If he has a drv error, the focbox is toast and needs to be replaced. So it also looks like he tried to run detections at 11.1 volts which some its so slow, pulled more current than his supply can handle. Which lead to an improper detection and after he test spun it, he likely ruined the drv chip.
Sending a replacement to you and our tech team will guide you with the setup
