Hey man where is that motor mount kit for only 75$
sorry I’m late, but TQ has discontinued that particular kit. you can look on his website for something similar
Hi I am new I want to make a e-skateboard I am on a budget I bought these 2 esc and 2 motor off hobbyking and would like to know which Lipo I can used to get max speed etc
Dual motor
The Turnigy SK3 motors are suited to modelers who are seeking a quality brushless motor without compromise. Specs. Turns: 14T Voltage: 3~4S Lipoly RPM/V: 1200kv Internal resistance: 0.028 Ohm Max Loading: 38A Max Power: 560W Shaft Dia: 5.0mm Bolt holes: 25mm Bolt thread: M3 Weight: 111g Motor Plug: 3.5mm Bullet Connector
Specification: Max Cont Current: 40A Max Burst Current: 50A for 10 seconds Input Voltage: 2-6 cells li-XX or 6-16 Ni-MH/Ni-Cd battery BEC: 5.5V/5A Switching BEC PWM: 8~16 KHz Max RPM: 240,000rpm for 2 Poles Brushless Motor PCB Size: 50x25x12mm Weight: 43g (including wires)
Those motors and esc will not work very well for esk8. It is possible but you will need a large gear reduction ratio to achieve a good amount of torque.
Read this
Hi I changed my esc and motor 2 each what do you think
Specs. Schaltet: 18T Spannung: 10S Lipo RPM / V: 190kv Innenwiderstand: 0,028 Ohm Max Belastung: 65A Max Leistung: 2450W Wellen - Ø: 8,0mm Bolzenlöcher: 32mm Bolzengewinde: M4 Gewicht: 697g Motorstecker: 4 mm Rundstecker
n: Max Cont Strom: 60A Max Burst Strom: 80A für 10 Sekunden Eingangsspannung: 2-6 Zellen Li-XX oder 6-16 Ni-MH / Ni-Cd - Batterie BEC: 5,5V / 6A Switching BEC PWM: 8 ~ 16 KHz Max RPM: 240,000rpm für 2 Pole Brushless Motor PCB Größe: 50x32x12mm Gewicht: 63g (inklusive Kabel) ** Programmierkarte benötigt Einstellung zu ändern
Looks better, for the esc though I would recommend either a Vesc or a Xcar beast esc
What the best lipo you would recommend
40c or above. 25c is also okay but you’ll have more sag.
Thank you very much bro
Minimum Capacity: 12000mAh Configuration: 6S1P / 22.2V / 6Cell Constant Discharge: 10C Peak Discharge (10sec): 20C Pack Weight: 1610g Pack Size: 183 x 77 x 56mm Charge Plug: JST-XH Discharge Plug: XT90
Dont buy that multistar shit… they`re more like 4c
I’ve never seen anyone use those before. They could work but some tried and true car escs are the x car beast, fvt 120a and max 5 or 6
I’ve used this esc in multiple tasks for 3 years. Durable as hell, basically waterproof. I highly recommend it.
