The planetary gears can be made if you got an indexing rotary table and a fly cutter. Internal gears require either the hobbing or broaching method. This can be done on the lathe also.
thanks everyone!
@Eboosted what @BoostedBuilder said is right. it is just an reduction. the same idea as an belt drive only now internal and with gears.
@Nordle nice im building also an cnc mill at the moment. What @pxss already said i made the gears with an EDM machine with an tolerance of 0.01mm. most parts i made are within 0.02mm because you dont want a lose bearing or put to much pressure in it.
Have you riden them or not?
From the video I see this is going to have a lot of drag, canāt say though if it hasnāt been riden.
I wonder if it would have any benefits over a regular hub motor
@Fatos No I was to enthusiastic that I damaged one motor. I fucked up the windings. I already contacted some motor manufactures but it is very expansive or the delivery time is end of January. Therefore, I will rewind them myself. I get the wire tomorrow so I hope to test it soon.
@Eboosted You can compare the friction with a belt drive I think. That is without the oil seal. I removed that because the friction was too high. I will now use grease.
Keep it up ! @fliess Look it up, how about trying this next year for your hubs
@Eboosted I get the feeling it should be ok since all revolving parts are centered around one single axis unlike with belt. It will make a big difference with riderās weight on it.
@Vanarian, I am still for proper wheels, if you wanna ride properly But in general, @Frank, my respect, very nice job!
Cool to see someone, who is planing to build in the DieBie Is that a 7s7p, or did you make some weird wiring? -Stupid question, 49 is only dividable by 7
Ok that doesnāt make sense huh My guess is 10s wiring looks like 7-7
Cool build log. Thanks for introducing to all the machining tools and jargons
I think your topic does deserve build of the year or similar titleā¦ too bad we dont have special category on the forumā¦
As everyoneā¦ really waiting to see it in action, looks like that projects like these do take some time to accomplish
On a side note, since you are good with machining parts -
What do you think about dual wheel drive with single motor, where there is a differential in the āmiddleā?
How difficult such project would be?
It is meant more for mountainboard, so there is more spaceā¦
I was originally thinking about fitting inner gear into existing wheel / outside of sprocket, then run an axle to the other side (with differential in the middle?) and then connect that to the second wheelā¦
If this would be possible within, lets say 50 - 80 eur range, that would be a success, since lowest cost for 5060 or so motors is about 35-40 eur, calculate controller + some wires on top of it = it becomes almost 80 eur,
plus the motor mount etc but im not including mechanical parts here.
So yeh, ācheapā single motor driven dual wheel āsystemā would be awesome, if it could be machined / made personally.
Ive got 6374 motor, so it has more than enough power to drive 2 wheels, I thinkā¦
The only unclear part is this differentialā¦ On another thread someone mention that for 1/8 size rc cars something useful could be found, since it is all metal there, tooā¦
This has been beaten to death in another thread. Check out endless sphere too. Those rc differentials donāt last, you need something 1/5 or 1/4 scale and it gets large and expensive
@Okami haha thanks! I hope you and all the others liked my topic and get some ideas/learned something.
I cannot also wait but because 1 motor is broken I need too rewind it first (didnāt had the time jet).
I think a differential wound be very cool(maybe an new project but I think it is not cheaper than an dual drive because you canāt buy an differential(accordingly to @ugothakd ) and making one takes time, lots of it I think.
I was preparing for you (and me) the surprise for this beginning of the year for air wheels ā¦ but you find it
Iām working on it since last summer (for my Darth Vapor Street Fighter version) thanks Frank for your inspiration !!
3d conception almost ok, full 3d print coming soon ! Some row pic - here 1st ā3d prototypeā :
Iām not sure what Iām looking at, but I like the sound and looks of it!
@Frank what is the final ratio of your gearing ? Did you sort out your shorted phase ? I wanna see the damn thing run
Ehm im not certain but if im correct 2,45. Not that much but the problem was that the inner gear will be smaller when you reduce it more and that would give problems with bearingsā¦
Nicee that I inspired more people to build an planatairy drive. You will learn so much by building something like this.
I am still hope mine will work but the experiance is already totally worth it
Well yea I got hooked by the idea haha, want to try it too ! Not right now but yep!
