I’m not after huge speed or anything. Will this blow up or anything? I’m normally pretty good with electronics but I thought getting opinions from those with experience in this particular application would be wise. Can I run the receiver off the BEC built into the X-car?
How come the higher kv gives better torque?
For the mechanical side I am using an alien power systems motor mount with the 15mm pulleys from an ebay kit. Using Paris trucks and 83mm flywheel clones. I’m not sure how I’m going to make the enclosure yet, I’ll probably vacuum form something until I sort a better solution.
Thanks for the advice
Is that for the smaller form factor? I was planning on making a mod for the GT2B to make it more convenient but if there’s another reason to use an alternative then I will need to do more research
Thanks
That kit sucks. I bought it and was thinking i’d safe a lot of money, but i ended up buying everything twice cause it didn’t work well. Worst part is that the pulleys and belts are HTD3 which have far smaller teeth than HTD5, so if you accelerate or break hard, the belt will slip a lot. Also the motor mount didn’t hold well on my trucks at all. I ended up getting pulleys, belt and motor mount from @esk8 Far more expensive but it makes all of the difference.
