Those are the old bolt in RKP mounts though.The press fit uses some of that space and then the mount plates have to mount inside the flange. You lose about 20mm
SK3 6374 are 87mm
The new SK8 6374 are 89.15mm
Please confirm/deny definitely so everyoneās not wondering.
Youāre awesome!
The 6374 (89) are too wide. They donāt have a key way and the flat spot is goofy. The maytech motors are way better and they fit.
I blame @psychotiller for being a dickā¦ishly good asset to our group and coming up with the best idea Iāve heard of since crack. Aaand Iād like to say, I hope you and I can take (at least) some credit for this psychotiller-homework-assignment becoming a āwell informed decisionā instead of an inevitable impulse buy, @deucesdown . But all seriousness aside, Thanks for showing us what weāll be throwing money at you for 'tiller At least now I have a story foy my landlord June 1
Nite
Iāve got pink and blue coming!! No idea where I came up with that combo
Yet another pesky question:
Will these motor plates fully clear the kingpin? I ask because i have major space limitations on the inboard side , and with my ridiculous batteries, reverse mounting gives me perfect weight distribution.
At this point, I feel shitty for asking, but could you upload the measurements of the motor plate? Pretty pretty please @psychotiller ? As Iāve indicated (exhaustively) my finger is on the purchase-triggerā¦ And itās getting itchy. In fact, if you just clarify about the reverse mount part, I give. Thanks for all this trouble
It depends on your motors reallyā¦If they are short enough to clear the king pin there isnāt an issue. However, You cant raise them as high on that side because the motors will hit the hanger.
the motor plate has a 71mm center to center distance.
If you absolutely have to reverse mount. Use 50Ā° baseplates. The shallowness of the 45 is going to give you a headache.
Fffffffffuuu*k, I have one 45Ā° and just ordered a set of the 35Ā° trucks. What should I do? Iām going to email them to hold my order for the time being Edit: theyāre dual actual 6374s
Eh, roll with it. Mock it up, see what you are working with. If you need to, get another base plate later.
Or wedge em! Make it work attitudes get shit done! You could also figure out a way to make room to forward mount your motors . Thereās always a way
My feeling is that is probably has something to do with schizophrenia
Hell-fu*king-YEAH:
Brother I am ready when you are!! Iām totally down to place a pre-order on a set as a courtesy for your accommodations. Just say the wordThanks Brotha!! You too.
The new thicker press on piece has arrived, But not the longer mount plates. For the record though, @mccloed has a set reverse mounted right now with normal plates and 6365 motors. No clearance issues anywhere.
I appreciate the update!!
Surfrodz is having a 30% off saleā¦code is Summer
You cant beat $111 bucks for precision trucks
Fuck Iām in ouch this will be expensive.
Why oh why doesnāt SR say what quantities are in each thing? spacers, bearings, are trucks in pairsā¦ lol.
EDIT I got the last 2 mounts. Working on the SR stuff nowā¦
EDIT yeah that hurt lol @PatRocks Iām joining the party!
