I tracked down an android device to try and use for this, but it is only a Nexus S 4G w/Android 4.1.2 build JZ054K. Looks like I need at least Android 4.4? I am having a hard time finding the right android update to sideload, can you point me in the right direction? I was able to sideload the Vesv Monitor app but got the expected parse error when trying to install on unsupported older hw and OS. Any help much appreciated, I just want to get something up and running (Wifi no wireless carrier) just for Vesc Monitor app!
Personally, i have to smartphone, a galaxy s4, and a “ELEPHONE S7”.
Since the last update only my S4 is ok with the vesc monitor application. The 2 phones are on android 6. Perhaps you can upgrade your phone with a cyanogenmod ?
PM me and I’ll get your device added to our supported list. I’ve been really busy with work and my wife was just diagnosed with MS so I’ve been dealing with that. But it should be no problem updating your device. We specialize in Nexus and open source devices.
@Ackmaniac I have been using your firmware for quite a while now and it’s perfekt. I have the latest version, the 2,54. But today, I wanted to check the reverse mode with no weight, it spinned for a couple of seconds full speed and then stopped I tried it again and the same thing happend. The third the motor didn’t spin at all, neither backwards nor forward. I connected it to my laptop and damnit… Fault : FAULT_CODE_DRV8302 Current : 0.4 Current filtered : -0.0 Voltage : 30.88 Duty : 0.00 RPM : -0.1 Tacho : 849 Cycles running : 3 TIM duty : 32 TIM val samp : 5 TIM current samp : 8398 TIM top : 8400 Comm step : 0 Temperature : 29.81 Any ideas what could be the reason for this? I have a sk3 6364 with a 8s Lipo and a esk8.de VESC and I run it in FOC
I guess you know what happened - Fried DRV in FOC mode. The classic
FOC on the bench can cause issues. Especially at full speed. Some motors run flawlessly and others are very sensitive. I guess it is because you give the signal to open the door for the current but the motor can’t consume it because it is already at max speed. But it also can be another reason. Best is to prevent the full speed issue when you reduce the limit ERPM start and end value in the PPM settings. When you set this to nearly full speed then the VESC will try to reduce the current when it reaches this speed. So for example when your motor reaches 55000 ERPM on the bench then you can set the ERPM limit start to 50000 and the end to 55000. For example when i go down a hill with my R-SPEC 6355 then my motors start to go crazy at full speed. They can’t go any faster and only produce like 300 watts even if i give full throttle. Because they are already close to their maximum speed. This starts at around 57 km/h for me. So i set the maximum speed to 58 km/h and say that it should start to reduce the power output at around 52 km/h. So i have no trouble with the motors anymore. But i also have to run them at a switching frequency of 30000 (normally 20000). Otherwise they are gittering so that my whole board vibrates and they also killed a DRV. Since i have them at 30000 everything is fine (Only the max speed issue which i solved by the settings above).
Also when you try to keep a slow speed on the bench by giving very little power can also cause issues.
On the other side the R-SPEC Ghost prototypes (Raptor 2 Motors) run without any issues in FOC. I think that the distance of the magnets to each other is important for the FOC capability. I could be wrong but this is the biggest difference between the motors physically (apart from the amount of magnets 14 / 28).
Hey Ackmaniac - where do you adjust setting to have it backoff power at 52km/h in the tool? Sorry if this has been answered elsewhere.
[edit] ignore this question - I was only thinking of the motor config tabs, I’m assuming you limit this under the PPM soft ERPM limits section
Same thing happened to me FOC was running wonderful before. Updated to 2.54 and tried reverse mode on the bench. Was fine when I stood on the board tho. Got the DRV fried. Its currently undergoing repair
A good advice would be: Don’t run Foc on the bench . People keep frying their vescs with it.
Maybe it’s just a problem with unsensored motors?
Hopefully this will be my last stupid question on this. I have 2 VESCX’s in CANBUS. Do I need to update the firmware on each one, or will they both update if I install the firmware on one? The second one is stuck down with adhesive tape, and doesn’t want to come out, and I don’t have room to fit a USB cable into the port. Ken
You need to update both and also make motor detection on each individual one. Thus step is important in order to rise smoothly and avoid issues
But you can update the VESC via the CAN bus. Just below the connect button you can select which controller id the slave vesc has and choose “CAN Fwd”
Thanks, hopefully one last question…In your install instructions, it says: "Be aware that this is only for Hardware Version 4.10 or above (VESC-X as well). Where do I find the hardware version on my VESCX? All I can find is it’s firmware version 2.18, and I received these brand new in March 2017. Ken
Every VESC-X works.
Thanks! Wish me luck as I’m diving in now! Ken
Using a MAC, the firmware quit unexpectedly. Every time I try to reboot it, I get the same error, although it does say I’m on Firmware version 2.54
Just simply reboot by powering the VESC off and on again. It’s the same. But just wait 5 seconds in between.
OK. I thought I had everything configured correctly, but my remote isn’t making the wheels turn
Did you setup the correct application. i guess you need to choose PPM in the App configuration Gnernal Tab.
