Are there any other BLE modules that can be used instead of the HM-10? My hope is to have better connectivity with Android 8.0+ (or any connectivity really).
The maker of the HM-10 says that it is compatible with 8.0, but the clones or āfakesā as they call them are not reliable with 8.0.
Iāve purchased from a couple different vendors and they have all been āfakeā it seems. Anyone have a source for legit HM-10 modules?
All of mine have ended up being CC41-A
There is a way of updating the chip on the fake modules which might help, @SeanHacker wanted to see if that might help. If you have an arduino you could try this: https://www.youtube.com/watch?v=ez3491-v8Og
But you should read this first:
is there a mac version ?
I just got a DRV8302 fault when I switched my board to 9S (I plugged in the batteries on the bench I didnāt ride it). It works perfectly fine with 6S, and when I switched back from 9S to 6S it worked as usualā¦anyone else have this issue?
I donāt know how hehe
Never a better time to learn. Itās a QT application
Let the journey begin. I donāt know how either, but if I wanted it bad enough, Iād figure it out.
Just use the free version. Works just fine. Iāve never used QT before this morning so Iām still learning about it and how things work. But I was able to compile a build for linux (something I need!!!) in about 3-5 minutes or so. I also removed the beginning pages so that I donāt have to read it every time I open the app. If I get a few minutes later Iāll compile you a Mac build. Gotta go ride before the rain hits!!!
Iām sticking with 3.1 firmware until metr and perimetr are compatible with 3.101 and until there is a Mac version of the tool.
Looking forward to this. @Ackmaniac
I am trying to use the latest version of VESC Monitor (V1.85) on a Galaxy S6 (Android 7.0), and although I see the bluetooth module, the second I select it in VESC Monitor, the App crashes. I didnāt have this issue a few weeks ago, so am wondering if there is a bug in the latest updated to VESC Monitor (V1.85). anyone else seeing this? @Ackmaniac
Fixed the issue already in the latest version 1.88.
3.101 is compatable with Metr mate, using it myself!
yes. it is now working. Thank you!
However, is there anything you can do to keep the app from crashing/freezing when the VESC is turned off? @Ackmaniac
Doesnāt happen with my phone. But i will have a look with my other one.
