20 Euros shipping, I will make sure it fits those specs
Do you want a BMS and charger?
Yes, BMS and charger. How much it will be for battery+ BMS+ Charger+ Shipping? How many amp BMS i need for 8S4P battery? What is last date to order?
138+25+25+20E shipping
77a BMS
Last date technically end of tomorrow
O.K. sounds good That bms will be already soldered to battery pack? How A is charger? Tomorrow i’ll make a payment:) Thru Paypal?
Also is it possible to order steel motor pulley-15 teeth, 12mm, 8mm bore with keyway?
16t is possible. 3a charger
How much for pulley? Yes, i’m interested!
Do want the motor pulley only? 15e for motor pulley
is it 12mm 16teeth and made from steel witht keyway? So no 15 teeth possible?
Still interested, do you sell a 15mm motor pulley and belt? Just printed a 15mm 36T wheel pulley and would like matching motor pulley and belt if possible.
Or can I use 12mm on this as well? 16T motor pulley is best for efficiency right?
Can pay today, hope you have time to reply.
16T/15T is best for efficiency depending on the wheel size.
I can only do 12mm wide sorry, but you can always print a 12mm wide wheel pulley.
True, but don’t think 15mm to 12 mm will be a problem, but that’s just a guess.
Sign me up for a 12mm motor pulley, set of wheels black and 3 belts. And shipping to the Netherlands.
I am in. How much and how do I pay you ?
90mm/83mm/97mm wheels?
22euros for 3 belts + pulley
Ohh this is very interesting! to bad Im a tad late, How often does theese group buys occur and how does it work with costums/vat?
