neopixels are pretty simple. my new lights use them.
this libary and examples are the best place to start. I would use a 5v trinket because you only need 1 pwm pin for lights. you can use the others for buttons. or the builtin button i think.
Noice. Well I made a new thread to chronicle the simplicity of the arduino led controller for eboards.
Anybody got a 3D file for a truck holder for those COB LEDs?
Hardly used. As new.
Have this light with original box and mounting bracket thatt can be screwred to riser. Comes with remote. Regargeable battery. Aus buyer preferred.
Made a 3D printed mount for them for under the deck: https://grabcad.com/library/holder-for-electric-skateboard-lighting-1
Not yet perfect as I might want to adjust the angle a bit and the mechanism is almost useless - on my print however the tolerances were so good that it fits perfectly and sits tight.
Anyone know where I can find some decent purple or pink LEDs?
Preferably something like these: https://hobbyking.com/en_us/3w-green-led-alloy-strip-120mm-x-12mm-3s-compatible.html
I have some blue ones going right now. Super bright, but no purple or pink.
If you are crafty and willing to build / get a led driver… try to search for 3w led chips or such… I think i’ve seen them in purple color.
U can also try these nobrand ones… will be cheaper but also possibly less light for the same watts…
Check color spectrum / look also, have not used / tested/ seen much of these uv/purple leds in real life
you could use rgb leds and set them to any color. I usually ride with purple or green underglow.
you could probably find a better price, but get this style mini rf remote. not ir! http://www.ebay.com/itm/5M-RGB-5050-Waterproof-Strip-17Key-RF-Mini-Remote-12V-5A-Power-SMD-300-LED-Light-/302025084634?hash=item4652190eda:g:5XUAAOSwaB5XmDMU
They look like this
from china might be a bit cheaper than the multiple color one’s.
Thanks guys, I didn’t realize the strip type LEDs were so bright. The color changing looks really badass
They also have rgb addressable lights
I’ve been keeping an eye out for bike lights that would work well for use on a skateboard. I ran up on this …
Oh. My. God.
I’ve used the dual led set from this company and it’s bright as balls.
This is just overkill
Yeah, I though it was pretty ridiculous
nice find… definately an overkill… unless you want to make an impression, there’s a 8 wheeler driving on the road
