Esk8 Range Calculator
Range is always important when you are building or buying. Heres some info on what affects your range for esk8 so you can know How far can I ride?
Direct link esk8 Range Calculator
Usually Wh is calcuated at nominal
True, but this is just an estimate and the numbers have matched close enough with real world range.
I added values to use nominal voltage.
Webpage shows that the domain has expired and is “pending renewal/deletion”. Any idea if there are plans to renew?
I don’t know if the webpage will ever be renewed, but I found myself needing the calculator today and there’s a backup saved on the wayback machine that works properly:
https://web.archive.org/web/20180823221553/http://calc.esk8.today/
Hope this helps!
