Hi guys, I know you all want to ride at full speed on this, but there is a CONFIRMED ISSUE with the pure carbon fiber lid blocking signals. 10 of you out of approx 30 have full carbon fiber lids, 20 of you have half Cf half Fiber Glass. Signal will likely drop out if you tend to ride with your hands up high.
Once again I didn’t test it riding with my hands up high, i never ride like that i always have my hand low… its stupid that I didn’t test for this… i am realising that i clearly didn’t think of everything before releasing this.
Please be careful until I can arrange new lids.
P.S. I just spent three hours riding the mono raptor side-by-side with a boosted board for a new compare video i am making. Not one drop out, not one problem with the brake on the Raptor…
I think what is happening to a lot of you is you are not used to the sensitivity of the remote… this remote operates in millimeters not centimeters, just like the GT-2B that many people use & love… So Please don’t jerk on the brake or the accelerator, you WILL crash.
Please think about how you drive your car, you jump in and slowly accelerate to a desired speed, when braking you apply the brake lightly until you come to a controlled stop. If you pull the brake on hard the board will instantly brake, the regen current limit will be hit and the motor controller will stop controlling the motor and it will release it. meaning you lurch forward again and go flying…
if you haven’t watch this video please watch it now.
EDIT: I stand corrected and I apologize… As Jason said the sensitivity is in millimeters not centimeters. I just filmed a video to send to Jason of the “all or nothing” with my remote and I can clearly see the remote is more sensitive than I made it out to be.
Understood, I’ll keep playing with it. As I said, I feel like I’ve learned where the stick activates the motors both for acceleration and braking.
I experience the issue with braking, whatever the sensitivity, in that braking is “all or none”, when I push the stick just enough to activate the brake, it brakes fully. It isn’t possible for me to do a controlled stop.
Same with the acceleration. Even when I baby the throttle forward, nothing. nothing. nothing. then WHAM! there’s a point where all of a sudden the motors activate at full strength… it is not possible for me to accelerate slowly unless I pulse the throttle.
yes, xusia had recommend i take the battery cover off… so i did.
I sent you a video. And again, you are right about the sensitivity of the throttle control. I was incorrect in stating that it took centimeters. Sorry about that.
I don’t own a Raptor but I do have the Enertion remote and I have the same experience, the trigger feel is a bit too “all or nothing”.
I was playing around with settings in the VESC last night and I found that decreasing the dead-band will make the board react to the joystick faster, but still jerky.
The only way I could get smooth and gradual acceleration is to set the PPM control mode to PID speed control but then I had no brake.
Setting the control mode to PID speed control with brake turned out to be dangerous, because the board went crazy backwards after braking hard.
I’m assuming you don’t have a way of identifying who has what lid material by their serial number or order number, correct? Is it possible we could tell by the weight of the lids? I don’t yet know if I suffer from a poor connection to my remote (as I’m not running yet) and have no idea if my lid is 100% carbon fiber or a carbon fiber and glass mix. I was wondering if there might be a way to tell which I have. To me, just looking, it looks like carbon fiber. That said, I expected carbon fiber to be less heavy. I thought, perhaps, the grip tape was throwing of my perception. Anyhow, I weighed mine to be 381.5 grams or 13.4 oz using the same scale. Obviously there is a margin of error here as those two numbers don’t directly correlate. Perhaps if enough people can weigh their lids we can better identify the material type we all have and better understand the impact of the material type on remote reception.
Is anyone else able to weigh their lids? If so, please do, and report on the quality of your remote’s reception.
Has anyone successfully updated their VESC? I downloaded the software (Windows version), but the method and/or settings to connect to the VESC are not obvious to me, and I could not find them searching. Any help would be appreciated.
@Xusia What is is you’re trying to do? A firmware update? If so, is it for a specific feature of the new firmware? I have seen this before:
If your simply looking to change some settings, I think it’s pretty straight forward having looked into it a bit a playing around with the software. Phsicaly it should just be USB port on your windows machine to the USB port on your (master ) VESC. I have seen some reports of issues connecting with a USB 3.0 port and directing users to use USB 2.0, but that seems strange. Hopefully it isn’t a problem because the only machine I have with a USB 2.0 port is an Nokia Booklet from 2010, and it’s freaking slow. I don’t yet have the ability to physically connect as I’m waiting on my right angle adapter. I started a thread related to Raptor specific VESC programming. Maybe you could post more specifics about what you are looking to accomplish, or difficulties your having, there.
Edit. I don’t know whey this didn’t show as a reply. Edited to add the @Xusia to the top.
Mono Rapter pulley rubbing. Noise is more pronounced when riding. Unfortunately that angle is not adjustable, unless you bend it. Which I did bend back, then after riding for half an hour the noise came back. Also when this happens, it loosens the belt tension, and allows the belt to skip teeth, which is dangerous. The mono motor is a great and powerful motor, unfortunately it is mounted on a week bracket. Mind you I was not riding aggressively. With the sensitivity of the controller and that great torque, the drivetrain suffers severely. This to you Onloop.
The flanges on the motor pulley need to be there!, they hold the belt in position, they are meant to touch the belt.
The fact that you can move the mount so much tells me the bolts are too loose. Please take the time to check over the fixtures to ensure they are done up tightly…
I have clearly written this in the user guide that everyone has got.
After further review of the loose bolt issue I think I have identified the problem. In some of the motor mounts we received in the last batch, there was an excessive amount of tapping lubricant inside the bolt holes. Normally the anodizing process would remove this and leave a nice clean hole.
Coincidently we switched anodizing factories on this batch too, so maybe they have a different method of cleaning. or just not as thorough. Their anodizing is definitely better though
Anyway, it would appear that the thread locker never set properly due to the excess lubricant.
I strongly recommend that the two bolts that hold the motor clamp be removed, holes cleaned out with de-greaser and bolts reinstalled with fresh thread lock.
Lol Onloop please tell me your not as simple minded as the replys you just gave me. No one is saying the motor pulley flanges aren’t supposed to be there. What I am saying is that the belt shouldn’t rub on the flange that way. Rubbing like that generates heat, and could easily snap the belt on a long ride. Onloop take your time and look at my post. The mount is NOT loose I can assure you that. That creaking noise in the video is the bushing on the truck, NOT a loose screw. That video was demonstrating how the mount is incorrectly positioned causing that noise. Stop dodging facts.
The red angle is causing the belt to try and run off, but it cant, because the flange is there to save the day. Oh one problem, an overheated belt will weaken and shorten the life of the belt. Lol dude this thing sounds like shit when i riding it. Are you sure you want to go down this path with me?
I’m pretty sure thread locking the bolts on the motor mount would fix your problem. Your diagram even points to that as being the fault with the angle occurring where the truck meets the mount.
If your two bolts holding the mount onto the truck become loose, the mount will no longer be straight, hence the belt rubbing.
You are correct sir. Only one thing, ALL bolts/screws have threadlocker and haven’t come loose since. I dont see why its so hard to understand the concept of something bending smh… For your information i was the original post that told everyone to check their decks for threadlocker. The threadlock issue was only my first with this board.
