Thanks Lox,
peel of what comes of then use “BrakeCleaner” and a towel. The trick is not to use to long the same place on the towel, change it often and aply breakcleaner. One Motor one Minute this way
@whitepony I thought alot about your last comments. I still think that a further reducing of the reduction is maybe problematic with the available Motors. Dont forget that on 12S even the 149kv Turnigys will give you over 50kmh Vmax.
BUT: Actually it would be even with the 1:5 Gearing possible to be inside of the wheels. The axledistance is 60mm and Motor radius is about 32, so by 200mm Wheels you are INSIDE. I really thought about if the small round braces could be as good as the known horizontal braces. And in fact they cant be, if we maybe completely go without them the mount will get more compact. There would be no need anymore to be bigger then the motors. As you said (-;
Maybe another way for additional motorprotection could be to adapt something from the underside of Truck where the Springplate is attached … something like a brushguard as mentioned by @mmaner
I would like to ask @trampa : Is it possible that the trucks are not machined out of one zero point? So if you wanna have the best alignment to the Steelaxle you have to seperate both sides?! Thanks for your help Frank.
