Which is why I am not just giving you a link that will answer your question.
The most important part is to get familiar with the way things work. You will only get there by reading.
It will work fine your.board (motor) will have more room.
A lot depends on what batteries.u gonna use, as that might limit “available power” way more than what motor rating says.
If you run motor at half the max it will be.just cooler and wont struggle as much.
Remember esc - speed controller, is just the middle part between battery and.motor… it regulates how much and.in.what way motor receices the power, so battery / esc adjustment.will.bring more difference than motor.choice
