as far as i can tell the motor is just fine. went in and soldered the loose wire and then shrink wrapped everything. I’m just going to get a new VESC at this point.
It’s a little frustrating to start a new hobby and have the VESC go so soon. $100 down the drain to diyelectricskateboards.com. His policy is that you can pay $75 for a warranty after the fact and get 1 replacement. So if I am reading that right, after shipping, for the same price, I can get another…
Any suggestions on a ESC? Should I get that replacement or go with someone else?
Seems like you have to pay ~$160 to get a VESC with warranty that will actually work.
Continuity through each phase is normal, there’s about 0.1 ohm in between each phase (*** depending on each motor) you won’t be able to mesure that kind of resistance w a normal multimeter.
The other photos, the windings of the motor have a isolating coating on them, don’t scratch it off, it can cause the motor to fail pre maturaly. So it’s pefectly normal you can’t mesure anything that way.
The motor phase should be isolated with heat shrink, did you remove it?
I got 2 Vescs with heat sinks from Chaka.
Expensive but they have worked perfectly from day one. And I do a lot of hard up hill driving.
The loose joint on your motor could have been causing the problem that you had with the motor not spinning but jerking back and forth.
You should hook it back up to your Vesc and try it.
I believe the consensus is that if you want the best quality Vesc with the best warranty then get the Chaka Vesc from Ollinboards.
You get what you pay for. He is pretty clear in the description on warranty options (none included, $60 upgrade to warranty):
[quote]VESC BLDC Warranty
No frills, affordable VESC with no warranty. At our current price
point, we would not be able to provide a full warranty on VESCs.
However, they are tested before shipment.
The VESC is highly susceptible to damage if used incorrectly. It is
still and a beta product. Enjoy being on the cutting edge at an
affordable price! We do our best to get you up and running with no
problems. Please watch our YouTube Videos on setup.
We do extensive testing, loading the bootloader/firmware, testing
BLDC mode, motor detection and testing FOC mode. We run the tests 2-3
times. If we are able to do the following with no issues, the VESC
is ready to be shipped.
Still want VESC Warranty? Purchase our additional warranty VESC BLDC with Warranty.[/quote]
A $60 and few bucks USPS to send back seems like the best and least $ option. Ollin’s VESC’s are gorgeous and will work well for you too… but it’s ultimately another $100 you can choose to spend or not. Yes there are a few extra caps he’s refined (and Vedder didn’t include in the current BOM), but for your minimal setup i don’t think you absolutely need it.
A DRV chip is only about $6. Have any friends who can do SMD re-work or repair? some flux, heatgun w/ reducer tip, and about 20-30 min if you are going slow and it should be done.
I have one to repair myself (bought dead), but would probably pay the $60 to get another from @Torqueboards.
It’s $75 after the fact for @torqueboards warranty and it covers 1 replacement for one year. So ultimately i would be paying ~$95 to get a replacement (with shipping) and no additional coverage if it has the same issue.
So basically i would just be buying an additional VESC with no warranty.
I would recommend for people buying these products to get an Enertion Platinum VESC (with warranty) or @chaka VESC that includes warranty. ~$160-180 for a VESC with 1 year warranty is a lot better than the $100 I spent to be cheap and now will spend $180 to be safe.
@Carvin_Ginger - You can go ahead and pay the $60 and I can send you a replacement upon receiving the broken DRV option. However, I would probably recommend you go with Chaka. That way any future issues are resolved. We offer more of a no frills, you know what to do with it VESC.
And/or you can purchase from Chaka. Chaka hands down has the best warranty but you pay for it.
If I had more time or resources to repair DRV’s for everyone I would.
You do need to know and understand that the VESC is BETA. VESC 6.0 will be a lot more robust and stable. Sorry for your experience with the VESC. For as many people who break their VESC there are hundreds of people who use it on a daily basis.
@Carvin_Ginger We will be glad to have you as a customer! Our VESC listing has a drop down menu with many different connector options. Our warranty is unlimited, if your fry it several times we will still repair your VESC.
After 1 year we may ask you to pay for components but honestly we will probably just take care of it beyond a year. We make these here in the shop so repair cost are very low.
If you are frying your DRV every time i’d be willing to bet it’s configured or setup improperly. Either too high KV, or some missuse frying the chip.
Given the correct components and general good quality assembly - these things are not that fragile. I have 6 from at least 4 different places (1 remaining direct from Ben) and except 2 i killed from my own stupidity - all going strong. the 2 i killed was bench testing 12s - hard start/stops repeatedly troubleshooting the ABS and other over voltage error. Adjusted the settings fixed error, but testing it i killed 2 drv’s.
You’ll have great luck w/ @Chaka’s VESC’s. If you want to send your dead one to me i’ll see if i can repair and return to you? If able to fix it’s a spare, you just pay materials and shipping. PM me. (and no i’m not going into VESC repair business, just trying to help a brother out). I have a 10 pack of the DRV’s for mine (back-up) and want to practice repair (did 2 with assistance from a friend).
I got my board back together with everything but the VESC (should be here tomorrow).
I took it out around my hood to make sure nothing was rattling. The motor (or belt) keeps catching every 20-30 ft. Anyone have a similar problem? Is this a motor problem?
That looks fine for belt tension. You can try removing the belt and see if the noise is coming from the wheel. If its not then its probably you motor, which you can open up, clean and lube the bearings.
Also, if you have a snap ring on the shaft, check if its hitting the motor mount, i had that happen to me and it made an awful sound.
