Thanks for the info guys, are those drop mounted setups using diyeboard trucks and motor mounts ? Also, how did you modify the rear bushings, are there any brands that fit DIYe trucks, specifically the 9" ones? Was looking at doing that but it seems like the clearance would be so small because of how thick the 10s5p battery is.
Just so you guys know the diyeboard 6-9 inch trucks with there 35 tooth pulley fits the abec 11 107mm wheels and new slick revolution 110mm rough stuff wheels…
Direct fit no modding to the pulley!
I’ve just ordered the power truck kit, so there will be a review comiing soon. I’ll probably change the gearing setup to 10:38 gearing and use the mbs all terrain. Do you think that this is a good idea?
Yep try um and see… let us know how it works
Thank you for this info
Could it handle 12s? Or am I best off putting my 2 6s packs in parallel instead?
You can usevesc with their hubs no problem but don’t use vesc with their outrunners because it will fry your vesc by going over the erpm limit. But i definitely advise to change to VESC you got more power, more torque, more speed and more smoothness
it can’t, only handle 42v maxim. can’t support 12s.
Hello jason,
Could you give us some news on the new hubs motors that will come out during this spring/summer ? Any news on the planetary hub ? The hub with replacable PU ?
Do you have the new meepo hubs with the upgraded PU with better quality ? My PU is already wearing out and i only done 200 km.
Every normal abec core should work just fine.
MBS and other bigger wheels uses a special stronger core.
We will update new items here when it is ready for sell. but we are not firm sure about the new arrivals availlable time, new items takes long time to develop and probally cancell in the progress.
Any update on 30Q battery packs?
Will arrive in April
We are schedualed sell it on April.
Okok just update us on those hubs it’s very important for many of us I think. Side question your actual hubs are with the newer version with good qalaity PU ?
No joke, this is very usefull for me thanks for using the left over foam trash as packing for my battery pack it came in use as padding so the battery pack wouldnt move inside the enclousers!
Oh you lucker
Hahahah, now i have 7 battery packs lol.
