But i can send you one right now
no thanks. Wanna be sure with all the other things too. And then i will contact you:)
No problem
So just double checking. You know, im on a budget. And that means the first thing i buy gotta be the right one .
So is this a good setup for me? Or anything else you recommend?
Single Motor Mechanical Kit Link
And then the deck you showed me .
Are you making your own battery pack?
Hi Joakim!
I’m using the exact same parts for V2 of my build, except I’m going with li-on batteries and a BMS which gives me a one plug charging solution. For my first build I went with four 5000mah 3S batteries which was a hassle to charge. Go with li-on batteries from start and you’ll be happy that you did! My lipos went puffy after only 20 charges each.
I’m in the process of building my own pack and since I’m located in Sweden I could put yours together too while I’m at it. I’ve already got a spotwelder and I’m just waiting for my BMS and shrink wrap to arrive. PM if you’re interested.
I bought 24 of 18650 batteries to make a 6S4P battery. Then I’m going to pair it with this BMS and charge it using a regular laptop charger.
The batteries+BMS+laptop charger+water resistant ports cost me about $213/1900SEK/1457DKK.
Lipos might seem like cheaper solution but eventually(for me it didn’t take very long) they will break.
Is this a one off sale?
@UniqueSnowflakeN27 I think a lower kv motor with an 8s3p pack would work better, 6s 245 kv is only recommended if you have no hills and a low budget, as it doesn’t give much torque! @ajaynagra he had a couple lying around and he sold both now
@SirDiff You’re absolutely right! Either way, I can solder it all together if he chooses to go with lion instead of lipo.
Hi i searched around the threads looking for a fellow swede that was in the process of building an esk8 and i was wondering i could Contact you with a couple of questions?
