Do you limit the throttle or ESC. ? Mine just launches with 97mm and 16/36
As in fly off the board.
What are your VESC settings? and What motor are you running? Iāve got a more aggressive torque (90mm wheels and 13/36 gearing) and have not had that issue once I got the settings dialed in.
the remote also helps. i use the 2.4ghz mini, the throw on it is a lot taller than then thumb controlled remotes.
so thereās more articulation in controlling throttle.
but if youāre getting jerky on / off throttle, somethingās off with your settings.
Iām using the mini remote as well. The whole setup is pretty smooth. However if you are standing on the board and ask for 100% the power is there. Itās dual 6374 190kv
I have just added support for PayPal and Apple Pay! Woohoo!
MBS 100 mm dedicated wheel pulleys (36T, 40T, 44T) with sprockets. There are NON available in the entire planet. Non existent.
Thatās afirmative, Son.
@JLabs I was just about to buy a FOXBOX mount with that free shipping code you put on the page but it only saves 7$ out of 32$.
Is that correct? Thanks.
That is free shipping in the USA. Shipping for the mount to the EU should be $14 so I will just refund the extra amount that you paid
Ah cool, thanks.
I did not place the order yet, shall I do it and u do the refund afterwards or u send me a code or something to put it beforehand?
Will check out with PayPal, am I the first?
I canāt give a coupon for shipping unfortunately. You can just checkout and Iāll refund it. You will be the second
Perfect, thanks, I will hit the button after dinner.
Just wondering if you got the tax thing straightened?
I was wondering if anyone would be interested in 12s4p and 10s4p 30Q packs. They will have a BesTech 80A BMS and all the fixings. They will be pre order only because they take up a lot of capitol. Shipping in late January / early February.
12s4p - $379 10s4p - $299
Both will have the BesTech BMS with eSwitch, Charger, and % display. Flat pack style to limit height. Pre order only, price does not include shipping to you. USA only.
This is just a feeler, nothing set. Iām not sure if there is any demand, so let me know if your interested.
I would be I interested in one of each, depending I. The geometry.
They would be flat, but to but with just shrink wrap, no hard casing like before.
Iām down for 1 if each of you wait till after Christmas for payment. Pretty tapped out for a couple of weeks
No problem, I can cover a few of them, just not 10 of each
By the Fri after Christmas I should be straight. Just trying to stay out of savings and credit cards this year, if possible.
@JLabs Might be interested in 12s4p depending on length. Not sure how long that with four FocBoxes would be like
