Nicely done! Great job! Also a very good use of these 2812 leds! I still got few of them laying around (single units), did not have proper pcb to solder them onto!
This is awesome! I especially love the turning animations with the flashing arrows! Something that may interest you are these 12V “15W” white head lights I found on eBay. I’m using a similar kind that are “10W” and I love them so far, but I don’t think there bright enough so these “15W” ones might be better. http://www.ebay.com/itm/311770165023
Would also love it if you shared maybe some schematics or code, but that’s up to you!
P.S. wattage is in quotes because I don’t think any of the are actually 10 or 15 watts lol.
those look like overkill lol. these lens i have make a rectanular beam. so you light up full width even close to the ground
I made these to work on the esc 5v output. the headlight is a 3w led, but it only uses 1.5w at full power.
this leaves just enough current on the vesc 5v for maybe 10-16 rgb leds.
i’m cleaning up the code, and making a schematic. it seem like theres more interest in headlights and brakes. singals were just a easy way to test…
Oh you mean the 15W LED, well there not overkill cause the “10W” ones I have are not bright enough and are not even close to 10W lol. Hopefully these “15W” ones will be good enough.
still finishing up the schematic and cleaning the code. I made the circuit almost half as small. simple enough that a custom pcb doesn’t make sense, yet. at this size it would be pretty cheap…
yea its the 85. the headlight has a mosfet for upto 500ma, and leds are ws2801 rgb. so its shared 5v, 1 pwm pin to control. no worries of power draw…just limiting overall current to <800ma for vesc.
I still have some changes to make on the code but the circuit is simple. just a few resistors and pins/connectors/wires.
this is pinout for underglow/brake/turn lights. p4 is unused. i’ll update it with mosfet version soon…
thanks that was the idea…
it connects p3 to ground when pressed
will be used to configure to a new remote + changing modes maybe…
for now I’ve been reprogramming it. but for someone without an isp programmer, or code phobic the button means I can seal away everything and leave reprograming as a bonus, not a requirement…
I have enough spare parts to put together a kit, or ready to go set. pm if you’re interested.
ok the brake and turn signal version is complete*.
but there is a small limitation that the ch1 input won’t be read while animating the leds.
I tried to work around it with code but no real improvements so far.
With the headlight I wanted to have control at all times, but I didn’t want to lose the nightrider animations…
you should probably slow down or stop if you need to adjust you headlight anyways right?
