BLDC throttle sensitivity
Can anyone point me in the right direction to modify the sensitivity of the remote throttle curve.
My board is a 12s setup wih dual jackb hub motors and it reaches max power when im only pressing like 25% of the throttle. Basically i hit top speed at 25% throttle leaving most of the throttle range useless and causing some unexpected rapid acceleration some times.
Ackmaniac modified the VESC firmware and tool to add a throttle curve -
What remote are you using?
If you have the Enertion Nano X it’s really difficult ti set it up with good throttle response
That little chinese mini remote that has a circle to stick your finger.
I did everything and it works so nice! Thanks man.
thats the nano, or winning remote :wink:
Thats right!
