Okay I have already been talking about my issue on a pre-existing thread but I haven’t gotten any responses and am feeling pretty desperate.
Here’s my situation: I have assembled a 10s5p Board using LG-HG2, a Bestech BMS w/ E-switch rated to 80A and a 42v 5A xlr style charger. I didn’t spot weld them together but instead made custom battery sleds which have been working great. I soldered everything together using the diagram from Bestech and a combination of information that I have learned from this forum. I have checked all the voltages from the balance leads as well as from the charger and everything seems to be in order. I even replaced my first BMS with the second one I got from Bestech and I’m still having the same issues. The only time I have ever gotten the board to charge is when I unplug/plug in the balance connector which allows the charger to begin charging for 10 seconds before stopping again.
If anyone has any thoughts that would be WONDERFUL as I am extremely frustrated seeing my board run, but only when it is plugged in.
Is the pack already fully charged. The BMS won’t allow it to charge more than 4.2v per cell.
Check the cells and make sure they are all around the same voltage and then check the pack in total and see what u get.
I now believe that my BMS is only charging at the 50mA balance current and not accepting the full 5A charge from the charger as the pack now reads 36V in total and each cell has increased as well. I believe that this means that my BMS is not broken as I was afraid of so again if anyone has any ideas on what I can do that would be super helpful!
No, I was completely wrong lol. You have it wired like the picture from bestech. There has to be something we are all missing. It is highly unlikely you received 2 defective BMS’s.
Yes all of the Balance leads and sleds are all registering the correct voltages. The sleds are connected by 30A fuse wires. I believe that my e-switch works, I’ve checked the voltage across the wires when they’re disconnected and run it is series with a multi meter to check what Amps it’s pulling when it’s switched on.
