Now comes the sad part. Unfortunately I didnāt take any photos of the finished setup for this build before I rode it but essentially it ended with the motor mounts giving up all together after a few days of riding
Now Iām going to be perfectly honest, once the build was finished I rode it and beat the hell out of it for 2 days straight. After waiting in anticipation for over 3 months all I wanted to do was ride into the sunset and all through the night. Well thatās exactly what I did and holy shit balls it was fucking amazing!! It was honestly the most fun Iāve had in ages. Way more fun than the Bajaboard that I rode sometime ago. I rode it up and down 25% gradient hills continuously, I rode it on the beach, in the rain, on the footy ovals, basically whatever the terrain and whatever the weather I rode through it
So here is my verdict on some of the parts after abusing the crap out of it the past two days:
The motor mounts: Well obviously as I said they failed only after a short time of use. No they didnāt snap in half or anything drastic but the screws that hold the mount in place came loose and dropped the motors on the ground. I made sure to use loctite on all screws and let it cure for 48 hours. The reason the mounts loosened is simply a design flaw. The point of contact is only on the screws themselves since the plate doesnāt sit flush on the truck hanger. Additionally the position and orientation of the screws is such that there is not enough clamping force exerted on the mount onto the hanger. Just take a look at the photo and youāll see what I mean. From a design perspective the mount offers no where near the amount of structural bondage to the hanger that other mounts would provide.
Maytech vescs: These were the parts I almost expected to fail. But after doing consecutive hill climb after hill climb they held up just fine and performed beautifully. I have the end cutoff temperature set at 90 degrees C and never once did it hit that. The brakes are way too strong at the moment so Iāll have to reduce max brake amps.
Note that I only weigh 60kg or so, That definitely plays a part in the amount of stress put on the electronics. Thus at a max of 30 amps each they arenāt really under very high loads especially in a dual configuration. Thus the outcome will most likely be very different if these vescs are used in a single drive config with a more moderately sized user, decide carefully and buy according to your use case scenario. Even though these have performed fine so far, just spend the extra cash on a more reliable vesc.
Jlabs sealed motors: Even though they donāt look so good after being scraped along the ground they are awesome. Great protection with the sealed design and they never got remotely warm, even after extremely steep hill climbs consecutively, obviously me only weighing 65kg plays a part.
Trucks: the trucks were fine during my testing. They look like Paris clones I guess. The bushings on these make them super carvy and not really suitable for speeds over 30km/h.
Deck: Well as you already know the deck snapped in the middle. So I duct taped the shit out of it and rode it anyway! You may think that this was the dumbest thing I could possibly do and I agree with you! But it did hold up after my abuse and I will no longer ride it ever again. Already ordered a brand new flex 2 vanguard
So should you buy from Chinese vendors? I think the short answer is no. I was really hoping I could save a significant amount of money but in the end I couldāve saved a lot more if I had just bought quality parts to begin with. Sure the maytech vescs are holding up for now but I cannot recommend the deck or any of the mechanical kits that sell on taobao. In the end whatever you build you want it to last. By buying quality components or making your own quality parts you end up saving money in the long run since youāre not constantly replacing things. Nor should you be putting your safety in the hands of inferior components.
So what now? Iāll be replacing mostly everything I think needs upgrading with better more quality components. This starts with the deck which Iāll be replacing with a flex 4 vanguard. The trucks are going to be replaced with 44degree midnight satin red caliber IIās with enertion style dual motor mounts. Iāve also purchase genuine 90mm 75A ABEC flywheels. This build will be on hold until everything arrives, eta for the mounts is probably another month In the meantime I might pull the battery apart, add a bit more reinforcement and insulation and measure each parallel pack. Until then, stay tuned
