Hello
This is my new project.
is a Ben Hur deck by emotive longboards, just felt in love with the wood and overall shape of this board. ( bad that the battery is going to cover the underside). what i want with this board is to use it as a GT board something i can take for a 30 miles ride. it may get heavy but i can live with that.
it is 37.5" X 10.25" and it have a nice rocker.
my intentions are to equip it with the mountainboard MBS Matrix Pro 2 trucks and 200 x 50 mm wheels by means of a custom aluminium base.
also started working on a machined aluminium motor mount for the mountainboard truck if the price does not get too high will make a batch of at least 20 in case someone will like to make a mountainboard.
So far some pictures of my progress
The Board
compare to my Vanguard is not too big or maybe it is
Profile view
it will be around 5 cm higher than the vanguard but still stable with the MBS trucks.
Already have made the truck base using a aluminium tube of 3x2x0.25 in cut to a 35 deg angle, cover with a 3x0.25 aluminium bar them attached together with 8 M3 screws per base.
aluminium tube and bar you can get here:
and from a scooter store a pair of 65T 5mm HTD pulley for 15mm wide belt.Attached it to the MBS wheel hub using spacers and longer screws, for the holes just draw them in autocad and printed it on clear sticker paper using the pulley center hole as a guide.
For the aluminium mountainboard motor mount still working on getting the cross section of this trucks. i have made some prototypes of a clamping ring and 3d printing them but the shape have proved to be a little elusive but i am getting close now.
3d Prints of ring clamp
This Matrix truck 2 i really like, the hanger is just straight all the way and it can be use for any type of wheel (maybe fat tires for the sand) just need to come up with a mount that can be place anywhere alone this hanger.
The VESC i order from OllinBoardCo. i was honestly on the sidelines with the VESC due to the BETA nature of the device but after following @chaka work and his innovation on the thermodynamical side of the PCB and proper all round clean soldering on every device he builded i just had to jump on board.
for the rest i’ll be updating as things come alone
