I am offering a soldering service for batterys, prices may variate for the amount of cells/batterys/orders, since the more batteries i get, the less i pay.
At first ty @Okami for this information:
GUYS: SOLDERING DOES NOT DAMAGE YOUR CELLS IF DONE RIGHT - EVERY QUALITY HIGH POWER SYSTEM WITH BATTERIES IS SOLDERED.
I solder with leaded solder tin and soldering flux at low temperatures and high wattage, the cells will not get damaged.
Available cells for soldering: 18650 & (26650) - LG-HG2/VTC5/VTC6/LG-HE2/30Q/
Cells can be placed directly after each other to make short packages, sealed with hot glue/silicone/gasketmaker or urethane, or they can be soldered with plastic spacers.
Available connector types: hilumin, nickel, copper and fuse wire (so the cells are fused directly)
connectors available: XT90/XT60/Dean’s Ultra/EC5/Jeti(Hacker)/6mm Bullet (w/ 0,04 mOhm)/optional Antispark with (some of) the plugs
Possibility to ad a balancer or balancer wires without connector, since every bms got its own pin assignment - if you got the assignment, np
Sometimes i get some cells cheaper, right now 10S3P w/ 7,5Ah / 60A cont. - LG HE2 for 145.- for the lite version without anything but cables for connecting.
I can also add a charger with BMS so you just plug like a 12pin connector in your board and the batterys will be charged, this can save some space and lowers the danger of shorting components.
for more, hit me up please!
