FREE UK SHIPPING
JUST THE GT2B’S AND LONGBOARD LEFT
GT2B £18 ×3 available,comes with a free cable to connect reciever to vesc/esc.
Fully built longboard £45 ×1 available
FREE UK SHIPPING
Im UK based and might be interested, what’s the make on the longboard, trucks and wheels? And does the enertion mount fit?
Cheers
Hi the board is unbranded and you need caliber 2 trucks for enertion mounts.
Cheers, just double checking is the board new?
Brand new still has the wrapping on it if you look closely you can see it.
How much for the mounts if ur selling separately
Hi, no mounts left just what’s in the list at the top.
Cheers for the fast reply sadly only need mount
Do you have the enclosure mounting inserts and bolts?
What is the capacity of cells/VESCs/etc
Afaik there were different versions so not sure what they are
where are you based in UK might be interested in board if close
When I purchased it diddnt come with mounting inserts and bolts but I bought some so could throw them in free for you. I have a 10s3p and two vesc’s in mine I think maybe you could squeeze a 10s4p in. If your building a battery “10s4p” without spacers and in the grooves “40” there’s ample room for 2x vesc’s.
Hi I’m bournemouth if that’s close? Can deliver if your too far.
Yeah I’d have to think about this as was planning a 12s3p or 4p, I had seen pics of space cell and seems as you say no spacers
Ok no worries,I actually fit 80 cells in one of these once,stacked them up! it just means the seal wasn’t touching the board so I carbon fibre wrapped it to make it waterproof! Now i have a 10s3p because the other was way too heavy and tbh 30+mph is more than enough and can squeeze 15-20 miles out of it!
Do you know if this enclosure will fit a Trampa board ? I mean, can it flex ?
Do you have measurements of the enclosure? It would help
I’m sure a bit of flex would be ok as it’s plastic… just nothing drastic!
I’m interested in a battery enclosure
