Hi guys,
I have a small problem. I’m using a 3*3S 4.5AH LIPO pack and a 10S 60A BMS from battery supports.
The 10S BMS is of course compatible with a 9S pack! I contacted BS myself and they responded: “Yes, this BMS works the same for 9S battery pack, just leave the 10th balance wire with no connection, makes the 9th wire be the final positive output then it will work, as this is a balance board and independently charge each serial connection, it has no problem for 9S pack.”
So here is my wiring diagram:
Now the problem is how to merge the 3*3S balancing wires into a 10S connector for the BMS (with one cable w/o a connection of course since it is 9S).
I’m not that into soldering, so maybe someone has an easier solution?
Thanks!!
