Yeh, cutting down power once cell reaches certain ‘‘treshold’’ sounds reasonable…
Though… it pinpoints the ‘‘problem’’ which you are talking about… if load is not big, you can continue to ‘‘sip’’ the power from battery for longer period of time before it gets drained…
I’ve also seen charts where energy count graph is cut short, since load for cell was way higher… and the process was stopped way earlier… than when cell was discharged at very little load, for example…
@Namasaki
I suspect the ‘‘danger’’ might be way higher for these who dont use any other cell monitoring methods or ‘tactics’…
Generally, I think it can be felt quite easly if battery / pack is quite empty or close to depletation… setting some limits or ‘warnings’ of course is a good choice and just provokes / sustains longer battery life… if we assume cells might get a bit more damaged if overdischarged regularly…
On a side note… if talking about BMS’es, I think they can be ‘‘poked around’’ a lot… but the final fact, conclusion i have come to, is that they need to be functioning or of high quality not to cause more problems than they are meant to solve… have heard of too many stories of faulty bms’es which cuts power way too early, stops working, does not balance cells properly or cause some other issues.
So far Raphael Chang’s bms seems to be the most promising… but I believe he is only in early production phase as the first bms’es are yet to be received by the first customers / testers…
Sorry for taking this reply so long, sometimes it just happens when I want to adress more than one issue / argument to which I want to respond…
Though I still find it interesting that I was able to draw enough power to propel the board forward… but non the less, the last 5-10 mins i had of it riding slowly was not very ‘enjoyable’ in a sense that the lack of power could be felt drastically.
And to those who might not be aware, I did that on purpose to see how low the cells can go and what rest voltage will they sit, since there are still discussions about when power should be cut and when some time ago I came to conclusion that 3.3-3.4v no load voltage is a somewhat good point, some ppl were suggesting to deplete them further since there was still energy left…
