Hi Everyone, I’m in the final stages of my electric longboard build after working on and off for the past year. My parts list is as follows:
4x - 3s 5000mAh Lipo battery wired in series for a total of 12s
RotorStar 120A HV (4~14S) ESC Link
Turnigy Aerodrive SK3 149kv Brushless Outrunner Motor Link
For the remote I have an Arduino Pro Mini 3.3v sending a PWM signal to the ESC. With some brief test code I can run the motor and change speeds from a potentiometer in my test setup. However, this is while having the Arduino powered from a USB cable to an FTDI breakout board responsible for programming the Arduino. In my final setup I want to power the Arduino from a 3s lipo battery and a 3.3v regulator separate from the batteries running the motor. When I wire this configuration, the motor will not arm or make any noises, indicating that it is receiving the PWM signal from the Arduino. Trying to diagnose the problem, I have tried many different power sources including 9v battery, 18650 cells, and the balancing leads from the batteries powering the motor(all of these tested to the RAW pin on the arduino and additionally to the 3.3v regulator and the vcc pin) and none of these will run the motor. The only configuration I can get the motor to run is from a USB port(either from computer, iPhone charging brick, or power bank) to the FTDI breakout board and then finally to the Arduino.
I have tried everything I can think of to fix this issue but I can’t figure it out. Any advice would be greatly appreciated!
My second issue arrises when I try to use the Nyko Kama wireless wii nunchuck to control the board. The control is now very unreliable, only sometimes arming the motor and controlling it, other times nothing will happen at all and I will have to restart everything. Also, when it does work the acceleration is very jerky and it seems the motor will get choked up sometimes. Has anyone had success using the Nyko Kama to control their board? If so what nunchuck library were you using and what did your setup look like.
Thanks for reading this! I could use any help I can get. I’m trying to get this board up and running in the next 3 weeks so I can use it to get around at college.
Sounds like the 3v regulator is the variable that hasn’t been tested, and so therefore, might be the culprit? Have you tried another type of regulator? Bench power supply? Voltage divider using resistors?
The simplest thing that comes to my mind is a proper ground connection between arduino and ESC. Sorry if that is too obvious but i sometimes forget this too.
How would I go about establishing a proper ground connection? Currently I have the brown wire from the ESC connected to a ground pin on the Arduino and the orange signal wire connected to the PWM pin. The red wire from the ESC is left unused.
The RAW pin on the Arduino can accept up to 12 volts so I have already tried without the 3v regulator. The only reason why I would like to use an external regulator is because I have fried a few Arduino’s powering from the RAW pin before. I currently don’t have access to a bench power supply so that isn’t an option. How would I go about setting up the voltage divider using resistors?
Ok i meant hat. Do you have any access to oscilloscopes to see what the arduino does?
maybe a long shot, but you could measure the outputs of the esc (from the signal wire and +5V and ground), i once had a esc with reversed wires.
So did you plug in the 3S (11.1V nominal) battery into the arduino 12V input without anything in between (regulator/resistor), and the arduino still didn’t boot up?
