Another noob needing help on my first build
I’d suggest getting a mount that has an idler pulley to help prevent the belt from skipping since you’re only running a single motor.
I like the diye mount on Amazon. For a vesc, I would recommend a maytech
Could you link me to the mount? I tried finding it but cannot. Thanks! @AntiPusher
Could you recommend one in particular? I am not familiar with many brands, thanks!
http://www.electric-skateboard.builders/t/updated-v2-caliber-ii-motor-mounts-for-sale/46255
I personally use the first one from @marcmt88 and I like it. I’m sure @Boardnamics mount would be a good option too.
https://www.amazon.com/Premium-Electric-Skateboard-Caliber-Compatible/dp/B01N6AGCEL/ref=sr_1_4?ie=UTF8&qid=1519275204&sr=8-4&keywords=DIYE
it is used by @nmagz3
Maytech VESC’s are crap, do not buy that especially if running a single motor. Amps will kill it.
I would go to at least 90mm wheels. The mount @sender linked is a good one, I’ve got 4 of them. In fact you can get wheels, pulley, belt, motor, etc from the same place.
@JLabs, link this cat some gear :grinning:
What mount should I buy for the motor you recommended? https://hobbyking.com/en_us/turnigy-aerodrive-sk3-6374-192kv-brushless-outrunner-motor.html?___store=en_us I was looking at this motor mount, tell me what you think https://www.amazon.com/Premium-Electric-Skateboard-Caliber-Compatible/dp/B01N6AGCEL/ref=sr_1_4?ie=UTF8&qid=1519275204&sr=8-4&keywords=DIYE
I would get the 6374 and motor mount from @JLabs
Thanks for all your help man I really appreciate it, I did not know how complicated it would be to build! Would you mind if I rapid fire some questions at you real quick? Could you link me a good $80-$100 VESC? what other connections/wires would I need to buy? and would you suggest me to just get the batteries and sauter them all together in series? Id rather get like two zippy batteries, but im no expert. and what kind of charger/remote would you recommend? I’d really appreciate you answering these million questions :joy:
The DIYE motor mount has been hit or miss for some. For me, it’s been great. I’ve used it on 2 builds with out any issues. However, it has shifted slightly with some abuse and vibration. I’ve added some gaffer tape to the truck where the d clamp of the mount will sit. Now, it’s solid! Unfortunately, movement with any mount is inevitable and the very best way to avoid this would be to have the clamp welded to the truck.
I second the JLabs motor mounts. Solid!
If you are looking to spend a bit more cash the Ollin Board and FOCBOXs are of the highest quality currently. But if you want something between the Maytec and the pricey FOCBOX, I have found that Miami Electrics VESC work great even under high amps and heat. I’m not quite sure where the bones of ME’s VESCs come from (could be Maytech) but there is a fat ass heat sink right on top of the mosfets. I live in Vegas and in the summer it gets hot as shit which will effect the temperature of the VESC. In addition to that I have larger 97mm wheels, love going up hills hard, and have high amperage Lipos. All of these factors would have killed a Maytec VESC under hot conditions. But, I’ve gone a whole year with it never shutting down. LOL, sorry for the rant but for $110 I feel like the ME VESC is a total underdog.
The TB VESC is $99 collections/esc-speed-controller/products/torque-esc-vesc-bldc-electronic-speed-controller
If you buy the motor from @torqueboards you wont have to change the bullet connectors,
Look at this thread for a ton of info on Lipo’s, @Namasaki knows his stuff.
Here or Here for a trigger remote, Here for a thumb remote.
Is this topic still alive? If so, greetings everyone :slight_smile:
I’m total noob but quick learner looking for professional’s advices to build evolve GT AT looking, DIY. I read every single “read first” threads of this forum before posting the question, I got lots of insight, but not sure exactly how can I select parts of board at this beginner level, which components are compatible etc. Is this right address to look for help?
Cheers
B
Hi. There are lots of threads titled “first build” the could be a good resource.
Also the build section
Look for these “psychotiller” and “six shooters”
oh waow, thank you for the suggestion, the one below looks insanely good actually
https://psychotiller.com/product/6-billet-wheel-hubs
Thank you very much, I’ll check in detail!
Cheers
