How big are the differences between 6355, 6374 and 6384?
I could fit dual 6384 on my tb 218mm Trucks, but I don’t know If I should do it. Price is also no problem. So what would you do?
My Board is no mtb, just for the streets.
If you have no hills, you don’t weigh over 100kg and you don’t want to drag race, dual 6355.
6355 would save you some weight and you’ll still have a lot of power. Only thing is that it kinda looks weird on a 218 truck.
To be honest, even dual 5065 feel powerful, but 6374 is where all the fun begins! So if you are after a seriously powerful board, (it’ll most likely throw you off the first couple of times) get 6374. I feel like 6384 will be a waste.
If you talking about two of these bad boys on a longboard
Yeah they will fit on a 218 hanger
MAX POWER: 4000W
TORQUE: 4.5 NM
Let’s put that into a calc
So effectively you will create a longboard which could weigh anything between 10-30kg depending on board and battery and mechanicals choosen. Even if it were really heavy 30kg it would still be a third of the weight of a moped with the same power, and remember you don;t have anythign to hold onto…footgrip and position.
Outside of ATB there’s little point and increases the risk of injury for sure…powerslide anyone?
I run 15:36 on 107s, a bit for speed and I depend on the dual for torque, my top speed is too slow and my torque is not enough, or its just me wanting to go faster and having more torque
@Acido
