$360 Budget Steel Frame 6S Li-Ion BMS Build
Hi Guys,
Just finished my build. The goal of this was to make the cheapest functional build possible with a BMS to take me to work and back. It is a 10km trip with a decent incline. I really don’t think that a build can be done much cheaper than this with Li-Ion and BMS. I also wanted to try building a tubular skateboard frame and then enclose the electronics inside.
Anyways here is the build cost in case anyone is interested:
  • 190KV motor - $43
  • 6S2P Basen 26650 batteries - $50
  • Hobby King X-Car 120A ESC - $60
  • Motor Mount from @korryh - $40
  • Mini Remote - $35
  • 6S 60A BMS - $16
  • Battery Indicator - $4
  • 60A Breaker Swtich - $7
  • Caliber Trucks - $38
  • 83mm wheels - $27
  • 15T pulley - $4
  • 40T pulley - $14
  • 15mm belt - $7
  • 6s laptop style charger - $15
Total cost $360
The deck is made of some 20 year old plywood that I found lying around and the frame is made of some 1" round and 3/4" tubular steel that I had lying around as well.
I’ve only ridden it 6km to work so far this morning, so not much specifics to report on yet. Didn’t even have time to change the settings on the ESC before riding as I just finished it last night.
Will report back on range and top speed soon.
Holy shit. Dude you’re like the macgyver of ESK8.
Very nice budget build! I love the fact that you welded your own deck, that thing’s got to be heavier than a car though :joy:
hahahha! love this comment
Thanks man! Because it is tubular steel it’s not light, but it’s not unbearably heavy. I also made the handle as kick-tail, but mainly so I can drag it around like a suitcase.
Now that I’ve proven the concept, if I can find a welder for aluminum I would love to make one out of tubular aluminum.
Would something like that work with carbon fiber? I know nothing about this so that could be a stupid question…
Carbon Fiber in what way? There are a few carbon fiber decks out there already such as the Enertion Raptor.
Like using a carbon fiber tube instead of a steel one.
Could you send a link for the bms?
It is possible, but because you can’t simply weld carbon fiber together, joining the pieces of tubing would probably present more problems that it is worth.
A better option would probably be aluminum tubing with a carbon fiber top. That would be pretty sick IMHO.
http://www.ebay.com/itm/222233315789?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
cool build! You were really lucky with some prices!
where did you get 12 basen cells for 50$ from? the calibers? motor?
also your idea with a steel frame is brilliant :monkey:
love it! i really liked the idea of the handle in your deck :slight_smile:
How much does it weigh?
can you share a link to your laptop style charger?
thank you
Not sure how much it weights exactly, but it’s not light haha. The steel frame maybe adds 4 pounds if I had to guess. I don’t own a scale, but will try to weight it next time I’m by my parents place.
Having the handle makes all the difference. I would not even consider a build without one now.
The Basen cells were the only thing below market value probably. I got a great deal from @Namasaki
Caliber were just the cheapest one I could find on ebay. Motors are from HK
http://www.hobbyking.com/hobbyking/store/__51866__KEDA_63_64_190KV_Brushless_Outrunner_10S_2000W.html
The range on the 6s2p is good so far. I did 10km and still had over 50% on the indicator. This was on a route with decently inclined hills. With my gearing I have no problem tackling the hills, but if I had to do it again, would probably do a 6s3p. While going flat out on a flat part for a while and then up a long hill, I hit the LV cutoff due to the voltage sag.
I did the same hill at lesser speed yesterday, so basically with the 6s2p I have to be carefully about gunning it up hills as I will hit the cutoff if the hill is too long. If I do about 70% throttle, it seems fine. Still need to try messing around with some ESC setting though.
Weighed the board. It is 18 lbs. So not bad actually. I imagine it would be 3 or 4 pounds lighter without the frame.
damn … nice price! :smiley: wanted to do a low budget build too … but i think i’m already over my $$$ target.
Where did you get the wheels?
Thanks. Just search 83mm longboard wheels on ebay. I just got the cheapest ones I could find. It’s definitely hard to stay on budget with these things. My next build will probably be over 1k easily haha
Tested out the range today! Got 21KM!
I was able to do some testing today and went for a long ride. When I came back the battery had 29%, which basically means empty because of the voltage sag. At that battery level, I hit the low voltage cut-off with too much throttle.
I had to ease up on the throttle and wasn’t able to ride a top speed the 2nd half of the ride for fear of running out of battery and having to push the board back.
Anyways, I rode 21KM! So while these batteries don’t have the best AMP output, they do have great capacity. Remember this is just a 6s2p pack.
The path was mostly smooth with a few hills here and there. Anyways, my next build will likely be a 10s3p. I would estimate at least 30-40km with a pack that size.
What is the top speed like?
